HP (Agilent) 8510C Trace Read Timing/Busy Query
Hi all - I've been wondering for some time if anyone knows if the HP8510C
1. has a command that can query the instrument to see whether it is done with a trace
or
2. has a command that will let a programmer know when the instrument is done with a trace.
My problem is that I often have to read in subsequent trace data of the different S-parameters, and I don't know how to do it efficiently (one after the other, i.e. S11 then S21) and dynamically.  Right now I use a timer to wait a few seconds before moving onto the next trace, and that's definitely not dynamic.
Any suggestions by anybody would be greatly appreciated!
Euell
(3,355 Views)
Most modern network analysers use SCPI commands for GPIB control, I'd imagine the HP8510C does the same (check the Programmer's Manual if you have one). There's a common query (not instrument-specific) in this called "*OPC?" which flags if a pending operation has completed. I use it to control triggered frequency sweeps in Labview, where a trigger to start a new sweep is only sent when the previous sweep completes. Hope this helps.
(3,349 Views)
