HP 3314A Error
I am trying to control a HP 3314A function generator with my Computer. After downloading the drivers (http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=32E4FFE17FCF1253E0440003BA7CCD...) i wanted to test the example functions. It was possible to create the signal but i always got an ERR43 (ivalid data). In addition it changed a few settings on the 3314A function generator.
Does anybody know this problem? Why do i get this Error?
Thank you.
(938 Views)
Please attach your code to give a possible explanation
greetings from the Netherlands
(933 Views)
Some settings are probably changed because a reset is sent when you initialize the instrument (reset is true by default). For the error, as Albert said, post your code.
Ben64
(905 Views)
