09-13-2007 03:22 PM
09-16-2007 07:28 PM
09-18-2007 11:03 AM
Thanks....that helped a lot. I found a GigE Firmware Updater on the Jai/Pulnix website. Apparently "With the adoption of the GigE standard it is necessary to update the firmware inside some JAI, Inc. Gigabit Ethernet cameras to be GigE Vision compliant. This upgrade brings the cameras into compliance with the standard and allows proper access to GigE Vision control software." So as far as I can tell this is the solution I have been looking for. However, I am still running into problems *sigh*.
The Updater requires that you uninstall Cam2net (the camera software), but before doing so you have to make several changes to the settings of the NIC. However, I am having issues seeing the Intel Pro 1000 NIC in the Cam2net interface. Although it works fine as an ethernet port (appears as "wokring normally" and provides me with internet) the Cam2net software has it listed as "uninstalled". This means I can't change any of the settings and thus cannot proceed to update the firmware of the camera.
Is there any chance that anyone here has used the Jai Cam2net program and knows what might be causing this issue. I'm so close to sorting this out I can taste it....
W
09-18-2007 11:21 AM
