07-24-2018 07:22 AM
The response is incorrect. I am using a genuine GPIB-USB-HS purchased directly from National Instruments.
It does not report that it is not genuine when running NI-488.2- v2.8.1, NI-488.2-3.1.12, or NI-488.2 v17.0.
It reports not genuine when running NI-488.2-v17.6 and in that mode, it does not allow me to change settings or properties.
What should I do?
I don't know the exact purchase date, probably 4-8 years ago, but if needed, I can get a copy of the purchase order.
07-24-2018 07:30 AM
What should I do?
07-24-2018 08:19 AM
Start of by registering the GPIB-USB adapter on National Instruments website if you haven't already. This is found in the "My Account" tab and then "My Products". Afterwards check to make sure the returned registration certificate is reading the correct item.
I found that my GPIB-USB counterfeit adapter, which worked for a little bit, had the wrong product associated with it. I called recently and was told this likely means it's counterfeit.
I'm guessing even though your item is legit, a counterfeit item may have snagged your registration number.
07-25-2018 03:51 PM
Hi nengadai,
One troubleshooting step that I'd like you to try, is disconnecting the cable on both ends (USB and GPIB), then reconnect the USB end, then reconnect the GPIB end. Order matters in this case, so make sure to follow the steps in the order I gave them in. The reason I'm having you do this, is to identify whether or not there is a potential bug that we should be aware of
08-23-2018 05:52 AM - edited 08-23-2018 06:07 AM
Hello Tommy,
I am having the same problem - old GPIB-USB-HS, upgraded to NI-MAX v18 on new PC and suddenly the hardware is "not genuine" Error code: -37056. Hardware was purchased from NI years ago - not from ebay!
USB driver version: 17.6.0.49152
NI-MAX version: 18.0.0f0
09-06-2018 11:35 AM - edited 09-06-2018 11:36 AM
I'm getting the same error message too. The sad part is I know I purchased on NI...When I go to look at my past orders...all of the invoices pull up nothing. So I can't even verify this purchase I made way back when.
Calling NI to see if there's a fix I can use.
This device is not a genuine National Instruments product and may not perform as expected. Please contact your National Instruments sales representative for more information at ni.com/contact. (Error code: -37056)
09-06-2018 12:21 PM
After calling NI I discovered NI4882_1700f0.exe Driver or earlier will work.
09-10-2018 12:57 PM
If you are not using the HS+ option of the USB-GPIB controller, then this may be an option for you.
10-24-2018 08:24 AM
when I did this fix it worked. disconnected the the cable from both ends and reconnected the usb and then the gpib.
01-15-2019 06:33 AM
I have the same issue after updating. I registered my GPIB-USB-HS at the NI website and it accepted it so how can it not be genuine? Does anyone have a fix for this?
