04-12-2013 03:48 PM
I am looking for an 'easy' way to document my LV design and generate an html too.
I have looked through several methods and mostly concentrated on this:
https://decibel.ni.com/content/docs/DOC-18765
However, every attempt I did failed. It might be because I am inexperienced and the guide isn't that clear too.
The steps I followed made sense to me somehow but still I got a text file only, only once.
A little guidance through the settings would be much appreciated.
Also, if there are any other possible solution, please state.
I want a html to look like LabViews' Help environment...
ps. I would rather not implement this in my design as I have no experience in xml or http, I wouldn't know how to employ this, and I have a small relatively time to document, hence the above vi to xml documentation tools.vi
Thanks in advance,
Stav
04-15-2013 04:24 AM
Out interest - do you have the Report Generation Toolkit - it is an NI LabVIEW addon, which I believe comes as part of the Professional Distribution.
There is a whole sub palette that is purely for documenting LabVIEW code which TBH I've never used, but the rest of the toolkit I use on quite a regular basis and it is superb so I'd expect it to be of a similar quality.
04-16-2013 02:20 AM
David,
Thank you for the reply.
Unfortunatelly I do not have this palette. I only have a VI to XML documentation tool and a documentation tool for updating the vi properties. The first I can't get working, which is what this post is about. The second one I have used because it is easy to use and makes the documentation process much faster.
At the moment I am generating an html file from the print options in LV and modify it with kompozer.
This is the only solution I have for now and it actually works pretty well.
In terms of time consuption it depents on the outcome you want to achieve. For me, it can take up a fairly amount of time to put everything in order as I am using picture etc...
Stav
