GW INSTEK LCR819 LabVIEW Driver
   I'll   give a try to this..
         Need to complete this by monday...
        I'll keep posting..
Ing. Reynaldo Lima Villarreal
Ingenieria Electronica (I N G E L)
Reynosa, Tamps. México
Cel: +52 899 160-52-59
Email: reynaldolima@aol.com
Message 11 of 22
(3,518 Views)
    Heeyy..
    We made it..   I'm talking to the LCR...  Ir responds very quick,,   now I need to write the command I need and write the VI
    and complete the test sequence..
    Thank you very much....
    I'll really appreciate your strong support
    Best Regards...
Message 12 of 22
(3,514 Views)
 Hi Dennis
           I complete  the driver for the LCR,  it works OK...
           Now I saw it  simple,
           Still can't make the HP DMM  work with the USB to RS232 converter  FTDI Chip..
           I'll keep trying....
            Best Regards.
Message 13 of 22
(3,493 Views)
Hi Rlima,
can you upload the finish one?
Best Regards.
Message 14 of 22
(3,459 Views)
Hi everyone My name is Edgar and I'm new here in Labview I need help to develop the same System as Rlima but I don't had anything just the serial port and that's all I don't know what I need to use to comunicate with the LCR of GwInstek can anybody can help me with this I really appreciate the help anybodie provide
Thank You
Message 15 of 22
(3,364 Views)
 Hi Edgar...
     What is exactly you want to do..?
     You comment  you have de serial  port,   you got the LCR also.
     To connetion is not a problem,   just  connect the RS-232 cable to the  COM port on your PC and the other to the LCR..
      Best Regards..
      R.Lima
Message 16 of 22
(3,356 Views)
Done!!
This is the Software I found and works for me hope anybody can use this code for his purpose
Message 17 of 22
(3,323 Views)
We are using LABVIEW 2014 and wish to do measurements with GWINSTEK LCR Meter, Model LCR821.   We find that LCR meter driver is not available for a 64 bit OS.
Can anybody help ?
Message 18 of 22
(2,748 Views)
the easy way to solve this issue you need to create a virtual machine to do it work. use virtual box to solve it
https://www.virtualbox.org/
Also you would need the Iso file or the CD of any windows 32 bits
Message 19 of 22
(2,733 Views)
hi Rlima,
      Back to year 2014 regarding your project initially failed to talk to LCR - 800 series using RS232 that finally work, is it connect with NULL MODEM cable? Is there any driver software needed to install? can you share with me some idea how to make it work?
     Best Regards
   Henry Koh
Message 20 of 22
(1,968 Views)
