01-10-2014 03:00 PM
I'll give a try to this..
Need to complete this by monday...
I'll keep posting..
01-10-2014 05:15 PM
Heeyy..
We made it.. I'm talking to the LCR... Ir responds very quick,, now I need to write the command I need and write the VI
and complete the test sequence..
Thank you very much....
I'll really appreciate your strong support
Best Regards...
01-17-2014 01:09 AM
Hi Dennis
I complete the driver for the LCR, it works OK...
Now I saw it simple,
Still can't make the HP DMM work with the USB to RS232 converter FTDI Chip..
I'll keep trying....
Best Regards.
04-07-2014 08:01 AM
Hi Rlima,
can you upload the finish one?
Best Regards.
09-10-2014 05:14 PM
Hi everyone My name is Edgar and I'm new here in Labview I need help to develop the same System as Rlima but I don't had anything just the serial port and that's all I don't know what I need to use to comunicate with the LCR of GwInstek can anybody can help me with this I really appreciate the help anybodie provide
Thank You
09-10-2014 07:19 PM
Hi Edgar...
What is exactly you want to do..?
You comment you have de serial port, you got the LCR also.
To connetion is not a problem, just connect the RS-232 cable to the COM port on your PC and the other to the LCR..
Best Regards..
R.Lima
09-17-2014 12:33 PM
Done!!
This is the Software I found and works for me hope anybody can use this code for his purpose
07-09-2015 05:54 AM
We are using LABVIEW 2014 and wish to do measurements with GWINSTEK LCR Meter, Model LCR821. We find that LCR meter driver is not available for a 64 bit OS.
Can anybody help ?
07-09-2015 09:42 AM
the easy way to solve this issue you need to create a virtual machine to do it work. use virtual box to solve it
Also you would need the Iso file or the CD of any windows 32 bits
01-07-2019 06:38 AM
hi Rlima,
Back to year 2014 regarding your project initially failed to talk to LCR - 800 series using RS232 that finally work, is it connect with NULL MODEM cable? Is there any driver software needed to install? can you share with me some idea how to make it work?
Best Regards
Henry Koh
