09-17-2015 09:43 AM
Good morning, I'm quite new with labview and I have some problem with the GPIB communication; Dealing with a Tektronix TK2465BCT, I have connected an adapter GPIB-USB-HS to my Windows8 PC, when I try to communicate with the instrument through NI MAX it seems to communicate properly or at least it is recognized by the PC on the right address, as soon as I start a VI downloaded from the driver page of the instrument it doesn't detect the oscillocope. Any Idea? Thanks.
Solved! Go to Solution.
09-17-2015 10:47 AM
09-17-2015 11:05 AM
09-17-2015 11:16 AM
09-18-2015 03:58 AM
This morning I've tried to communicate again with the instrument and I understood that the problem is on the usb converter because as soon as I connect and communicate for th first time is ok if I disconnect the PC at the second connection the address used seems busy or not sending signal on GPIB,
anyway attached there are 2 different tries I have done.
Thanks.
09-18-2015 05:23 AM
