03-24-2011 03:57 PM
Hello!
I have an Anritsu MS9001B1 optical spectrum analyzer and am looking for the GPIB command set for it. Does anyone have it, please? I contacted Anritsu, but they said the service for the unit ended about 10 years ago and they don't have manual any more.
Thank you very much!
03-25-2011 10:54 AM
Hi lq747,
I looked through our resources, instrument driver network, and online some, but unfortunately I was unable to find this information. Has anyone else out there used this device before, or perhaps knows from where a manual may be obtained?
Stephanie R.
03-25-2011 12:16 PM
Hi Stephanie, thank you very much for your reply. I could find someone selling the manual on eBay. But the $110 price seems a little too high for me... Could someone please share one or tell me a cheaper source? Thank you.
10-20-2019 10:17 PM - edited 10-20-2019 10:37 PM
I see this is years too late, but in case anyone wants these commands again, here are what I have found...
These were found on an Anritsu MS9001A, but I assume they will work on both. I also don't have the manual, so I just tested stuff till it worked, so some things might not be completely accurate.
They are given in an attached txt file too in case the formatting is weird here.
- L Trainor.
Turn commands into queries by adding R. e.g. "SAR" -> what is the start wavelength? All commands and replies are ascii. I don't know what terminators are needed; I just use /r/n and don't care if this is not needed. Commands are not case sensitive. I prefer to write all in upper case except for the letters i and o (to distinguish from 1 and 0) Some important queries are given. Most commands have an associated query. MOST IMPORTANT COMMANDS: command mnemonic example action MM Main Marker MM0.805 set main marker wavelength PSR Peak Search PSR read power at main marker wavelength These allow you to place the marker and read power at that point. There are 501 points on trace, so use these two commands for each point to get trace (work out where the points should be beforehand). It takes about 2 minutes for the whole trace. IMPORTANT: command mnemonic example action RP RePeat RP do repeat sweep Si SIngle Si do single sweep ST STop ST stop sweep STR is sweep going? Will not register a sweep has started till about 2 seconds after you tell it to do one Lo LOg Lo0 (int) set scale to log. Integer argument corresponds to a specific dB/div e.g. 0 -> 10dB/div Li LInear Li1 (int) set scale to linear. Integer argument corresponds to a specific mW range e.g. 1 -> 100mW SP SPan SP1 (int) set span. each integer corresponds to a specific value e.g. 7 -> 10nm RE REsolution RE3 (int) set resolution. each integer corresponds to a specific value e.g. 3 -> 1nm CT CenTer CT1.2 (float) center wavelength in micron SA StArt SA0.8 (float) start wavelength in micron So StOp So3 (int) stop wavelength from using integer corresponding to required span SoR returns FLOAT of stop wavelength in micron iN INitialize iN sets osa to startup config. Wait about a second before trying any other commands Hi HIgh Hi1 High sensitivity on = 1 / off = 0 LV LeVel LV10 set top level COULD BE USEFUL FOR TEMPORARY SAVING: command mnemonic example action SV Save SV0 0-9 memory save RC ReCall RC0 0-9 recall memory (won't display anything till you use GD) GD Graph Disp GD display graph NOT SO USEFUL (FOR ME): command mnemonic example action SR SpectRum SR spectrum mode TR TRansmissionTR transmission mode LS LoSs LS loss mode WAR WavelengthA WAR what is low end of range for osa WBR WavelengthB WBR what is high end of range for osa AT AuTo range AT perform auto range UNKNOWN: command mnemonic example action HC Half Center ?????? HW Half Width ?????? MC Memory Clear ?????? PC Something memory related?????? LM LevelMarker LM5 set level of marker. I don't know what this is for DM Data Memory DM2 sets data memory number. I don't know what this actually means CP CoPy CP Print copy
edited for a couple of errors
10-20-2019 10:55 PM
I see this is years too late, but here's what I have found...
I found these commands for the Anritsu MS9001A. I assume the command set didn't change for the MS9001B.
I also don't have the manual, so this is just from my own testing, so it might not all be accurate. I'll attach a .txt file with these commands at the end in case the formatting is weird here.
- L Trainor.
11-08-2023 04:21 AM
Hi all, in case you need it, here you have a matlab code to retrieve data from your MS9001B1. I do not recommend using a market to get the spectral power, better using DMRX, where X is your memory, it can be 1, 2 or 3
