GPIB-USB-HS not detect in Keysight IO library suties.
Hello all,
now I am trying to connect a Spectrum analyzer (4395A) to the computer with a GPIB-USB-HS(National instruments)
GPIB-USB is detected in NI Max. but nothing can be detected in Keysight IO library suties.
I have checked the Tulip box in NI-VISA option (passports).
And attached below is the captured screen of my NI MAX and Keysight IO library suties.
Any suggestion for me?
Jacks.
(3,508 Views)
Hi korea)Jack,
I would first download and install the Keysight Drivers. You should be able to find this from Keysight Website.
If this does not fix the problem, I would try with other PC or re-install VISA.
NI-MAX screen shoot(1.png) looks like not right. your GPIB-USB-HS should be looks like below.
If the GPIB-USB-HS is correctly recognized as above and install the keysight driver, you can follow the next steps.
(3,463 Views)
You also can try with another USB ports.
(3,462 Views)
The following KB is talking about the same case as your case.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LoOSAU&l=ko-KR
(3,456 Views)
Thank you for your attention.
i changed the USB port another one.
so i solved this problem. everything working well.
(3,433 Views)
