GPIB IEEE materiel années 80
Bonjour,
Y a t il des problème connus de compatibilité entre les vieux matèriels ( années 80)
et les nouvelles interfaces IEEE ( USB-HS)
Actuellement cela tourne sur un vieux PC en emulation DOS
Merci
Message 1 of 8
(4,546 Views)
Hello, could you posted on English on this forum’s part.
Could you give more details on your issue?
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
Message 2 of 8
(4,456 Views)
 Is it problems of compatibility between the old machine (ADAMEL 1985) and the new IEEE interfaces (USB-HS)
Currently it runs on an old PC in DOS emulation.
the communication between the new PC and the  machine is not established
I test with VISA
Thank you
Message 3 of 8
(4,430 Views)
You need to provide some details. What is an Adamel 1985? Can you attach a manual? What error do you get? How are you trying verify communication? What command are you sending with the VISA Write?
Message 4 of 8
(4,414 Views)
it's a ADAMEL LHOMARGY DY26
is it possible to spy IEEE bus wiht GPIB-USB-HS ?
Message 5 of 8
(4,401 Views)
NI-Max don't create a  visa ressource
When we send "T" to the machine, it don't answer the "Test sequence"
Message 6 of 8
(4,395 Views)
Accepted by topic author thib_fr
A product brochure image in French is next to worthless. That does not have the programming commands. My guess in MAX is that you need to append a termination character. Read the programming manual.
Show the result in MAX after doing a Scan for Instruments.
Message 7 of 8
(4,390 Views)
hello,
This morning it's OK Smiley Happy
NI MAX finds the  HADAMEL's VISA ressource
and the machine answers to the query
Thank
it's probably a problem between the keybord and chair
with a termination character
Message 8 of 8
(4,365 Views)
