National Instruments does make an NI-488.2 DDK. This is source code for a
subset of the NI-488.2 driver. One of the examples that it ships with is a
driver for the PCI-GPIB board under DOS. Since this driver is a subset of
the NI-488.2 API (it only supports board-level calls), you may need to make
some modifications to your program, but it should be fairly straightforward.
Contact National Instruments sales for more information.
"John Prigeon" wrote in message
news:3973b5ac@newsgroups.ni.com...
> Thanks again!
> Although the system software is made in protected mode (Pharlap 3.1) The
> DOS extender can execute a real mode DLL, and that's how the existing
drivers
> are done. I'm willing to work on th
e changing the guts of my software to
> make it happen, but the PCI board just needs to work with DOS. I'll check
> out the vendors you mentioned and see what happens. THANKS!
> john
> "Makoto" wrote:
> >It is sure that NI PCI-GPIB does not support real DOS driver. I don't
know>about
> other vendors such as Agilent, IOtech, Capital Equipment, etc. Better>to
> contact them. But DOS drivers are typically function-incompatible>between
> vendors. Possibly you need rewrite GPIB low level I/O portions.>Also I
don't
> know if their DOS drivers work on the protected mode (DOS>extender)
correctly.>regards,>>Makoto>>>"John
> Prigeon" wrote in
message>news:396f4d2f@newsgroups.ni.com...>>>>
> Thanks for the message, but my system's software MUST run on DOS. It
is>integrated>>
> with a DOS extender program, meaning to port it to another platform
would>>
> be a harendous amount of work. Is there another source for a
PCI-style>GPIB>>
> card th
at will run on pure DOS?>>>> Thanks again..>> john>>>
