I'm working on test measurement application.
My test system uses GPIB-USB-B controller (National Instruments) to communicate between a Mensor, a DACU and my computer (Windows XP).
Software is written in Visual Basic .Net with Visual Studio 2005 environment.
I use Gpib-32.dll , and all the functions are in VBIB32 module.
A communication problem appears after ten
successive tests (sometimes after 11 or 12 tests). So I need to close the software and launch another time the executable file to be able to communicate again with the DACU. So when the crash occurs iberr = 0 and ibcntl = -535560191.
So why if I run a couple of tests (< 10) everything is smoothly, and not after 10 successive tests?
Other question what is the difference between ildev and ibdev?
The source code to connect the DACU is:
Sub Connect(ByVal Chan As Short, ByVal theType As String, ByVal Address As Integer, ByVal NumberReading As Short)
Dim EQP_ID As Short = 0
Address = Address - 700 ' fit gpib 32 protocol
'EQP_ID = ildev(BDINDEX, Address, NO_SECONDARY_ADDR, TIMEOUT, EOTMODE, EOSMODE) 'Get equipment ID
ibdev(BDINDEX, Address, NO_SECONDARY_ADDR, TIMEOUT, EOTMODE, EOSMODE, EQP_ID)
'* Sets the channel to be read by DVM or DACU
Select Case UCase(theType)
Case "HP 3497A"
Call ibwrt(EQP_ID, "VR5 VT3 VD5 VA1 VF1 VN" & VB6.Format(NumberReading, "0") & " VS0 VC0 SO1 SD1")
Call ibwrt(EQP_ID, "AI" & Str(Chan))
Case "SCANNER"
End Select
End Sub
Thank you in advance,
Sebastien
