03-26-2015 11:36 AM - edited 03-26-2015 11:43 AM
Greetings!
I'm currently working on the development of a Flash Photolysis instrument using Labview 2009 and have recently upgraded our computer but have run into some issues. At random points there is a generic I/O error within the messagesend.vi, but the errors do not occur when using the lamp tool. After doing some research I have found that upgrading our computer has caused some timing issues where the instrument and the computer are not communicating properly.
I was curious if anyone has had experience in changing the PCI-GPIB card settings so that the instrument will ping properly with the computer and fix this timing issue.
Thanks!
03-26-2015 02:26 PM
03-27-2015 11:41 AM
I believe you're right! I've found that my error occurs at the GPIBwrite command, would the two strings here cause a race condition during the writing process?
03-28-2015 03:22 AM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
