07-05-2013 07:22 PM - edited 07-05-2013 07:29 PM
Hi
I am using GPIB-USB-HS and CMW 500 to learn attribute based programing.
I am programming based on the VB.NET and I am using driver which is provided by Rohde & SCHWARZ.
When I am running the code to remote CMW500. I am getting error code "BFFF0038"
Therefore, I was asuming that There might have connection problem between my PC and CMW 500.( Or USB connection problem)
I ran the NI max to check the conndition for USB and It was showing this message "MAX could not open a VISA session to this static device. The device was not returned from VISA when finding resources, but MAX was able to use VISA to parse the resource name"
I am not really sure how to solve this issue.
I have attached screenshot for MAX NI
Does any can give me some solutions to fix this problem?
thanks
07-05-2013 08:36 PM
07-06-2013 11:13 AM - edited 07-06-2013 11:27 AM
Hello Dennis
Thanks for your helping.
Can I ask you How I can make sure whether I installed controllor(or driver) for GIPB USC properly ?or not ?
If I installed contoroller(or driver) properly , and I keep get this error message? ( I was using scan instrument function to detect device. However, it just returned "instruement not found".
What should I try to fix this problem (before getting new USB) ?
Thanks 🙂
07-06-2013 11:35 AM
07-06-2013 11:46 AM
07-09-2013 03:47 PM
Hello
I just solved the problem.
There is connection problem between instrument and PC.
Thanks for helping me
