11-01-2013 12:02 PM
I am developing some device to measure 3 axis movements.
This device transfers the data to the PC using UART (RS232).
I got the data in Hyperterminal but couldn't in LabVIEW.
The weirdest thing is that I can get the data in NI MAX like the
following picture. But I try to do the same job in LabVIEW there
is always error message like the second picture.
How can I solve this problem. I have searched through articles
about framing error using googling but I didn't find the appropriate
answer.
I'd like to thank you in advance.
11-01-2013 12:30 PM
Almost always the reason I have seen a framing error is a baud rate mismatch. Make sure all of your settings are correct.
11-01-2013 01:00 PM
Of course, I double check the baud rate.
11-01-2013 04:34 PM
You have neither shown the serial settings in MAX or in LabVIEW.
