09-02-2005 10:06 AM
09-06-2005 09:50 AM
Your code looks fine. A framing error is almost always caused by a serial setting mismatch. If your data is completely garbled, then baud rate is most likely the culprit. I found a KB that talks more about this:
http://digital.ni.com/public.nsf/websearch/13A20C0F9DF265FB86256FC60066D9C2?OpenDocument
I hope this information helps.
09-08-2005 11:31 PM
09-12-2005 10:07 AM
09-19-2005 10:52 PM
Mr. Michael,
I appreciate your help and ideas in this regard. May I know the Baud rate timing error, LabVIEW- Serial drivers can tolerate (in terms of some quantitave values) while decoding the read-data.
This is because the measurement board generates the baud rate using an on-board Crystal/Oscillator (in this case 40MHz) and it is suspected to have some error in clock generation.
I think you are the right person as you work for National Instruments to answer this query. Once again I thank you for your excellent support.
09-20-2005 02:36 PM
10-04-2005 01:57 AM
10-05-2005 10:17 AM
11-16-2005 02:24 PM
I saw the last entry and have a question regarding setting baud rates. I am trying to set the baud rate on my COM port to 56.7K and I am getting the following error (copied from "explain error" box).
Error -1073807330 occurred at Property Node (arg 2) in VISA Configure Serial Port (Instr).vi->Change baud rate.vi
Possible reason(s):
VISA: (Hex 0xBFFF001E) The specified state of the attribute is not valid, or is not supported as defined by the resource.
11-17-2005 02:32 PM - edited 11-17-2005 02:32 PM
Message Edited by Matt_S. on 11-17-2005 02:32 PM
