Error opening resource: ASRL10::INSTR VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the syst
Dear NI Community,
My name is Sophat Houn, a master student in Photonics and Applications Lab. in Royal University of Phnom Penh, Cambodia. I encountered the problem that "
ASRL10::INSTR
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system." when I am trying to open the VISA Test Panel in NI MAX 14.0. I used LabVIEW 2009 SP1 in window 8.1 Single language. If I can not configure this port, I could not control between LabVIEW and the stepping motor controller Model D120 SURUGA SEIKI because this controller used RS232 port and I used the NI USB-232 connector with serial number: FF7BB1 to plug in my computer.
I really need your solutions and advices because my work depend on this!!!🙏 I absolutely welcome every solution and advice from the Community. I will put the pictures below to make more understanding about my problem.
(1,727 Views)
Hi
You selected the parallel port instead of the serial one.
Try the com3 port that is a serial port.
greetings from the Netherlands
(1,717 Views)
Thank you for your solution. I will try this and I will let you know if I'm wrong at something.
Best regard,
Sophat Houn
(1,687 Views)
