Error connecting to textronix instrument with NI-VISA (Insufficient system resources to perform neccesary memory allocation)
I am using the NI-VISA .net driver in Visual Studio C# to create a program that can communicate with a MSO4104B Tektronix oscilliscope.
Sometimes, whenever I try to start a MessageBasedSession with the oscilliscope, I will get the following error shown in the picture below.
In the picture below, I'm using the Simple
ReadWrite.2015 code that is included as example code for the NI-VISA driver. I'm attaching this
example code to this post. I think this issue might start whenever I try to connect to the same oscilliscope via command prompt
(ping *ip address of scope*) or start a telnet session with the scope (telnet *ip address* *port*) at the same time my visual studio program
is running. However, even when I close all windows and restart my computer and oscilliscope, this issue will still persist for a while and then
sometimes randomly work another day.
Does anybody have any idea for how to debug this or what the issue could be?
Here are some pictures of the references added to my project:
Additionally, here's a snippet of the code I'm using in my actual program to start a session
with the oscilliscope. I have a mbsession.close() statement in my code, but it's not always called
because sometimes I exit the program early before all the code is finished. Could this be a potential
issue?
Some other important debugging information I got was from NI MAX and NI I/O. When this
issue occurs, I can no longer see the oscilliscope ip address on NI MAX.
I also used NI I/O trace to debug this issue a little more and got this output. I got an error
code whenever viOpen(*ip address*) was called. The error status was 0xBFFF003C which I
think means "Insufficient system resources to perform necessary memory allocation".
Anybody knows what this could mean? I have about 5 GB of memory so I think it should
be fine.
(617 Views)
1. may check the latest firmware of oscilloscope.
2. it may get into trouble while the exception of the mbSession was not created.
if(mbSession != null)
mbSession.Dispose();
Good luck!
(590 Views)
