Error 1386 with ThorLabs camera
I've been trying to use LabView 20.0.1 to control a ThorLab CS235CU camera. I pulled a VI and its supporting DLLs from ThorLab's program files, but after putting the DLLs in the proper folder and making sure everything was 64-bit, I keep getting error 1386 (screenshot below). I tried running labview as an administrator and tried creating the labview.exe.config text file recommended here. However, both these solutions didn't stop the error from occuring. The error occurs at step 2 (TLCameraSDK) through 4 when running with highlighted execution. I unfortunately cannot attach the DLLs to this post, as their zip is too large, but I've attached one of the thorlabs-provided VIs that I've been having trouble with.1386 error.PNGerror message.PNG
(1,114 Views)
tomcolburn,
Did you ever find a solution to this error?  I am experiencing the very same issue and I'm hoping you found a solution.
(627 Views)
I got it to work by entering the path to the library manually see screenshot
(575 Views)
I'm adding this in case others find a similar problem in the future. I had the same 1386 error attempting to use LabView 2023 64 bit to connect to a Thorlabs Zelux camera. I tried all the suggestions here and they didn't work. However, what did work was to make a different configuration file, the one suggested here. After this I was able to open and use the camera.
(358 Views)
