07-27-2018 04:30 AM
Dear all,
I am running the Anfatec203 LockIn Amplifier via LABVIEW using ethernet connection. When i use the VISA interface to read the current values of channels, there appears the error 1073807298 on VISA Read with error message - Could not perform operation because of I/O error. The code is still running well but the error keeps shown up.
Could someone who faced this problem or worked with Anfatec 203 LIA can take a look and explain me the possible reason and how i can get rid of this error from VISA Read in my situation. The real problem happens when i integrate this into the big LABVIEW program to control several devices at the same time. The error blocks the execution of reading when it is put into a loop.
Thanks a lot
Phuong
07-30-2018 05:10 PM
Hi Phuong,
Are you closing your VISA references properly? I just found this article, is it helpful?
Error -1073807298 Occurs after a VISA Read/Write
Mario
