Hello , ni engineers.
I am working on MODBUS using RS-485.
I Downloaded the Library from http://sine.ni.com/devzone/cda/epd/p/id/4756
After Installing the library , I tryed the MB Serial Example Master.vi .................but when I run it this error message appeares.
Error -1073807202 occurred at Property Node (arg 1) in MB Serial Init.vi->MB Serial Example Master.vi
But when I run MB Serial Example Salve.vi .................... It works fine.
I wondered what is the problem.
Thanks a lot for help.
Abdo.
