01-13-2024 03:51 AM
Hello
I have already solved the missing last value.
The subvi also got faster and more readable.
I tried to find the NOP? command but did not find it. It suggests number of operations but maybe it is not needed.
I did not solve the output of the for loop, Now you only have the last measured registers.
01-13-2024 11:05 AM
Hello Albert,
Thank you very much for your efforts and for providing me the code.
I think I found a way to store whole data in a 1D array without using a For loop. A command called "Delimited string to 1D string array" reads the whole string and saves the data to an array without the use of a For loop. However, I need to test it with the instrument and it is only possible after the weekend.
I will let you know if it works.
Please have a look at this command in the screenshot.
Best Regards,
Harpreet
01-13-2024 11:41 AM - edited 01-13-2024 11:51 AM
01-15-2024 07:36 AM
Hello Albert,
I tried your suggestion and the program is working fine now without any error.
I am also able to retrieve data without the use of a For loop.
Thank you very much for your help otherwise it won't be possible for me to solve this issue in this short time.
Best Regards,
Harpreet
01-15-2024 10:14 AM
