Drivers and PCI-1426 Library
Hello everyone,,
Sorry in advance if this is not the correct location to post this in.
I'm trying to install an NI PCI-1426 frame grabber and I'm getting a complaint from my app that the SDK and library aren't installed.
I've tried installing the NI-IMAQ package, which the documentation for the 1426 calls for, and the device was able to properly install the drivers, but I'm failing to find the library and SDK for this device. Are these still available anywhere?
Thank you!
(2,209 Views)
Hello!
Which device are you using and what library are you looking for?
Regards
(2,161 Views)
