Down grade issue with NI 488.2
I need to downgrade the 488 driver to regain support for GPIB/ENET-100
I have uninstalled all NI I can see and deleted directories.
Never the less, the new install fails with the following message. Any suggestions on how to clean my Windows 10 system of the listed products that are blocking the NI4882_1760f0 install?
------------------------------------------   error message ----------------------------------------------------
Cannot install
NI-488.2 17.6 (higher version already installed)
Configuration and Utilities (higher version already installed)
Application Development Support (higher version already installed)
LabWindows/CVI Support (incompatible with products already installed)
C/C++ Support (higher version already installed)
Visual Basic Support (higher version already installed)
DLL Direct Entry Support (higher version already installed)
.NET Framework 4.5.1 Languages Support (incompatible with products already installed)
.NET Framework 4.5 Languages Support (incompatible with products already installed)
.NET Framework 4.0 Languages Support (incompatible with products already installed)
(1,070 Views)
The most reliable and concrete method is to reimage your hard disk with a clean OS image - this ensures absolutely no leftover files.
Santhosh
Soliton Technologies
(1,051 Views)
Clearly true, but a brutal solution that destroys most installed applications.
There must be a hunting list of files (or registry entries)  that must be removed so that after a simple reboot of the O.S., the install cannot find any later version drivers.
(1,000 Views)
