Does this cable perform the same function as this NI box?
https://www.ni.com/en-us/shop/model/usb-232-4.html this is my niusb rs232/4 box, pretty sure it is broken, can I just replace it with this:
http://www.frys.com/product/8472038?site=sr:SEARCH:MAIN_RSLT_PG
I only use one port on it anyway.
(3,229 Views)
Hi LabVIEW212,
The cable you're considering isn't one I'm very familiar with. Here are the specs for the box you're trying to replace- if I were in your situation, I would reach out to the company that makes the new cable (it looks like it's Sabrent), and see what they say about the compatibility.
Good luck!
Kathryn K.
Technical Support Engineer
http://ni.com/support
(3,196 Views)
I use USB to Serial adaptors all the time with no issues.
BUT I do recommend getting an actual FTDI USB to Serial adaptor, not some cheap Chinese knock-off. Cheap ones have been shown to contain counterfeit chipsets and will cause you nothing but problems.
FTDI cables are available from Digi-Key for as little as $15 https://www.digikey.com/product-search/en/cable-assemblies/smart-cables/1574108?k=FTDI
=== Engineer Ambiguously ===
(3,144 Views)
