Does anyone have a vi for obtaining temperature measurements from a HH309A Omega four-channel thermometer?
I want to plot in a Labview program the measurements acquired from a HH309A Omega thermometer. If someone has a VI for this, please let me know.
Best regards.
(3,187 Views)
Do you want to acquire the measurements continuously?  ¿Or after any given time, retrieve the available data for processing?
Regards!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,174 Views)
Dear Anuar Rojas, thanks for your response.
The priority is to acquire measurements continuously for comparison with references, which will be used for temperature control.
Regards.
Marco Felix
(3,168 Views)
You can use the NI LabVIEW Instrument Drivers: http://zone.ni.com/devzone/cda/tut/p/id/9320
Also, there is a Universal Library for LabVIEW available for some OMEGA devices: http://www.omega.com/manuals/manualpdf/MLabviewRef.pdf
I honestly recommend that you ckeck put the folowwing websites:
http://zone.ni.com/devzone/cda/tut/p/id/12118
http://zone.ni.com/devzone/cda/tut/p/id/12402#toc2
You can use the NI VISA Instrument Drivers to communicate with the HH309A and extract the data as it is being acquired.  As a matter of fact, you can write the commands through LabVIEW and start acquiring inside the application itself.
Hope this helps!
Anuar Rojas
Anuar R.
www.ni.com/soporte
(3,163 Views)
