03-17-2006 09:50 PM
03-20-2006 11:18 PM
You'll then have to run the Found New Hardware Wizard once you reboot the computer. On the cabled PCI-232/16, were the ports in the same order in MAX as on the cables originally? Did the reinstallation change the order or just shift everything by 3?
03-21-2006 02:24 PM
03-22-2006 05:31 PM
Hi Dan,
The steps I outlined should fix this problem. The reason it occurred was because Windows discovered the ports in a different order this time. This is not expected, but it sometimes happens. The serial driver will assign the port names as Windows finds them. Normally, Windows would find the ports in an intuitive order, from beginning to end.
This may or may not occur in your other setups. It shouldn't. To try and prevent it from happening, you could follow the steps below when upgrading your software. But, like I said, it is not expected behavior.
