Lul,
Thanks for the rapid response... I believe I have done what you
suggested - In US Eng versions of WinXP, the Device Manager allows you
to set the port properties (which I did at 4800 baud). If I
open my *.vb file created from the Meas Studio VISATask (*.mxb file), I
can see where the read operation calls the "ASLR1::INSTR" resource
(i.e. COM1), but I don't see any settings (i.e. baud, stop bits, etc)
where I can add to the code. In the mxb environment, I set the
port properties to COM1, 4800 baud, etc. I assumed this should
translate into how the device is used when the class is automatically
coded in MStudio and instantiated at runtime? Somehow, the *.vb
file created using Meas Studio doesn't put the port settings in
explicitly (at least that I can find). Is there a way to modify
this vb file, or do I need to have to use the
VisaNS.SerialSession namespace and parse the file in code????
Thanks again for responding. Perhaps this is a bug in MStudio -
This is the first time I've tried building the VISATask graphically
(just upgraded to 7.1 pro from standard - one month before 8.0 came
out!!!!).
Tom
