Date code of GPIB-USB-HS+
We have several GPIB-USB-HS+ devices in our factory, but we would like to know how to decode the serial number to determine the Date Code?
What is the date code of s/n: 2010AD0?
Please help.
thanks
-Cu Nguyen
(1,152 Views)
Please help.
thanks
-Cu Nguyen
How does it help? what do you intend to do?
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,145 Views)
We are going to send this device to our CM in Vietnam to test our products.  Vietnam customs requests the date code of each equipment.
(1,119 Views)
Entering your serial number at Instrument Certificate Generator - National Instruments yields the conformance certificate that lists the date of manufacture.
Here is the one obtained for the SN you shared,
Santhosh
(1,095 Views)
Thank you for your information.
(1,084 Views)
Accepted by topic author redstar
Thanks.  The problem solved.
(998 Views)
Please make sure to mark the reply that answered your question.
"Thanks. The problem solved" is in no way an answer to your question.
Santhosh
(990 Views)
