DMM6500 Statistic Measurements Average
I'm trying to use Labview to perform a few Voltage, Current, Capacitance measurements. I do seem to have the basic communication [Ethernet VISA] working, but I think I might have a sequence of operation or settings miss match. LabviewTestingComm.pngI'm interested in the the average value for the measurement. I think I might be getting just the instant value instead the moment. [Average of sample 1]. [min/max values are exactly the same I don't think that should be the case]
I would appreciate any tips on how to set up my test-sequence or what I'm missing doing wrong.
NOTE:
When using the meter in local mode I can select continuous measurement and things seems to display correctly, but when using remote controlling [LV] it seems to be require a trigger [section 5 of the manual
(2,293 Views)
Accepted by topic author ceibanez
I think I solved my problem. When using remote you need to define the COUNT of how many samples to take. LabviewTestingComm2.png
Count when not specified it seems to default to 1.
(2,253 Views)
