05-17-2011 12:00 PM
05-18-2011 05:41 PM
Hi Warlox,
Can you tell me a little bit more about what you are communicating back and forth between? Are you trying to send serial commands directly to the motor or to a designated microcontroller? What kind of microcontroller are you using?
In case your interested in learning more about serial, here is a brief overview of serial communiation:
http://zone.ni.com/devzone/cda/tut/p/id/2895
A great place to start with serial programming in LabVIEW is from our example programs. You can find these in the LabVIEW Example Finder (Open LabVIEW, choose Help >> Find Examples).
05-19-2011 01:38 PM
05-20-2011 02:44 PM
Hi Warlox,
The serial commands depend on what kind of servo motors you are using, and what kind of microcontroller you are using. We will need to know what commands the motors are expecting to receive in order to know what commands to send. Can you tell me a little more about the microcontroller and servo motors you are using? Who is the manufacturer that makes them and what are their product numbers?
05-20-2011 11:59 PM
05-23-2011 09:48 AM
05-23-2011 05:43 PM
Hi Omer,
I found another discussion forum of someone who was doing a similar project. The information might answer all your questions. You can find that here.
Furthermore, do you have a soft copy of the servo motor and microcontroller manual that you can send me? I need to understand how the motors are controlled over serial to help you with you microcontroller and LabVIEW code.
05-24-2011 01:26 AM
05-24-2011 01:32 AM
05-24-2011 01:36 AM
