08-10-2005 04:41 AM
08-10-2005 05:03 AM
08-11-2005 05:56 AM
the following link may prove useful :
http://forums.ni.com/ni/board/message?board.id=180&message.id=17521
Also, what version of CVI, Switch Executive and IVI are you using?
What's the model for the ASCOR switch, and where did you download the vxipnp driver from?
Can you post your starting code here?
Can you post screen shots of your MAX configuration for the ivi instrument (logical name, driver session settings, hardware assett etc).
Sacha Emery
National Instruments (UK)
08-12-2005 02:11 AM
Sacha
Actually I found the problem last night - rather embarrassing finger trouble with the MAX. I'd cut and paste the resource string from a text file ("GPIB0::18::INSTR") so it had double quotes surrounding it in the Hardware Asset Resource Desciptor. Of course had the MAX error checking been any good it would have highlighed the error - he said in a rather churlish manner.
Thanks for you response
DWW
