Controlling Tinius Olsen machines through LabView?
Trying to control 2 different Tinius Olsen machines (Super-L and Lo-Torque, both with 398 displays) with LabView. Wondering if there is any knowledge of this or drivers available. So far I have found nothing. Currently have an NI9234 and NI 9219 modules.
Also wondering if there is any ideas on acquiring data from these machines. There are 2 extensometers plugged into the Super-L.
Thank you for any help
(4,255 Views)
Do you have any information from the manufacturer as to how the machines are remote-controlled?
(4,244 Views)
I'm having the same issue with a super L and I have the Command Structure for the 602 readout.
(3,937 Views)
Helo jkbk1969,
I would recommend starting a new thread with your issue since this current one is from a few years ago. This will allow your issue to be more easily seen by the Forum.  Be as descriptive as possible about what you want to do and what you have tried already.
Jonathan L.
Technical Support Section Manager
(3,893 Views)
