07-26-2017 03:29 AM
Hi everyone,
I am trying to use the ADALM1000 device from Analog Devices as a SMU, by controlling it with LabVIEW. This device has two channels from which you can chose to measure a voltage, source a voltage and measure a current, or source a current and measure a voltage.
There is a software (PixelPulse) that allows to do all of that but I need to be able to do it in LabVIEW, at least I need to be able to source a voltage and measure a current to plot IV curves.
So I was wondering if anyone has been able or tried to do that yet?
Up to now, I went through the source code of PixelPulse (which is available on the github of analog devices), to understand how to control the device. Since I am not really good in C, I still don't get everything but I know what library it is using (libsmu).
I was thinking of using this library in LabVIEW using those instructions (http://forums.ni.com/t5/Example-Program-Drafts/Using-Existing-C-Code-or-a-DLL-in-LabVIEW/ta-p/349923...), but I don't know if this is a good solution and if I will be able to use it afterwards.
Thanks in advance for you opinion on the matter!
07-29-2019 04:33 AM
Heyyy, could you figure out how to do it? I'm trying to do the same thing but I can't find any drivers to control the SMU with LabVIEW. If you know now any help would be very useful, thanks!
05-18-2021 02:08 AM
Bump, This would be awesome to have. Anyone out there have a solution?
Thank you,
-Matt
