07-15-2019 01:45 PM
Hello
I would like to control a metering pump with a CompactRio. The pump asks for 4mA to 20mA to be controled. I have the NI 9381 module but it seems to provide only +-1mA. Does a module, which can control my pump, exist ?
Thank you
Marianne
Solved! Go to Solution.
07-16-2019 12:29 PM
Hi MVDG,
Can you provide more details on exactly what your pump needs to be controlled?
07-17-2019 09:09 AM
Hello
Attached, you will find the data sheet of the pump
Thank you
07-18-2019 05:11 PM - last edited on 01-11-2024 05:17 PM by migration-bot
Check out some of our Current Output modules in the link below:
C Series Current Output Module
https://www.ni.com/en-us/shop/model/ni-9265.html
Something like the 9265 can give the 20mA
NI 9265 Datasheet - National Instruments
https://www.ni.com/docs/en-US/bundle/ni-9265-specs/page/specs.html
07-23-2019 01:14 PM
Thank you very much !
