09-09-2008 10:42 AM
Solved! Go to Solution.
09-09-2008 11:01 AM
The CB-68LPR is not a DAQ board - it's just a dumb terminal block.
Even if you have an actual DAQ board that is connected to the terminal block, it would be extremely difficult to try to emulate the precise timing you need. It could not be done without hardware time digital I/O. This question has been asked numerous times. The cost of a USB-RS232 is so little that it is just not worth the time to even try
09-09-2008 12:54 PM
