07-12-2022 08:41 AM
I'm able to send a simple command like Tare or send weight with the VISA test panel, but when I try to write a VISA command in Labview nothing happens. I'm ending the line with \r\n. I'm not getting an error using the VISA write to send the command. I have used this method before using labview to send commands to a Mettler Toledo scale but, I was using a RS 232 cable and I'm now using a USB cable.
07-12-2022 02:10 PM - edited 07-12-2022 02:11 PM
07-12-2022 02:56 PM
I did not select the mode. After selecting the mode code I was able to commutate to the scale. Thank you for answering my question.
10-17-2023 10:38 AM
Could you share the VI or the list of commands? I have Toledo with LAN as interface and I want to trial it
10-18-2023 07:26 AM
Mettler Toledo Scales have a set of commands "MT-SICS". You can google MT-SICS to get the list. The commands you can use are dependent on the model of your scale, the MT-SICS manual has the list. I used VISA commands for my code, at the end of the command write "/r/n", and make sure the string is set to code.
