Connection and Control of Circulating Water Bath Using Modbus
The following LabVIEW logic (see attached image) has been implemented for communication and control of the circulating water bath via Modbus. Although the logic itself appears correct, the system does not operate when executed.
I would like to ask whether additional modifications to the logic are required for the actual control to function properly.
Message 1 of 1
(166 Views)
