Connecting to a GWInstek AFG-2105 via USB
Good evening all,
I'm knocking off rust on my LV programming, and trying to incorporate a GW-Instek AFG-2105 Arbitrary Function Generator.  Ideally, I'd like to be able to specify sine waves (amplitude, frequency, and ramping) for an experiment.  The unit connects through a USB cable to my laptop, which is running LV02013 (and I believe I have NI-VISA installed; at least, I have VISA options in the block diagram functions).
  • Looking in NI, there don't seem to be any drivers specifically for this unit
  • Looking in NI-MAX, I'm not seeing anything (and I don't see any USB options under "Devices and Interfaces")
  • There doesn't seem to be any exciting "found new hardware" message when I plug the AFG into the laptop
  • Looking on gwinstek.com, I found drivers for Labview 7.1 that show up as a LLB file (which is new/forgotten to me). Through that, though, I can pull up a variety of VIs that I can supposedly link to, but I need a resource for them.  Presumably, I'd get that through MAX, which isn't seeing anything...
So where I am is slightly stuck, but certain it's something small I've forgotten.  Would you guys mind taking a bat and knocking me loose?
Thanks!
-G-
(5,939 Views)
The fact that you have VISA functions is not relevant. You have to actually install it. Verify in MAX. If the instrument emulates an RS-232 port, it will appear in MAX as a com port. The only other usb type of connection that would automatically appear would be a usbtmc type. The manual should tell you what type of usb it is.
(5,935 Views)
Finally got it to show up in NIMax using COM3.  Now I just need to keep hammering at it for a bit...
Thanks!
(5,916 Views)
