03-05-2013 10:09 AM
for a customized Class RAW USB device, I've used the NIVIUSBK.sys Driver
under Windows XP. And I've created the necessary INF File with the NI Driver
Wizard, which includes my own Vendor ID and Product ID. This works all fine
under Windows XP and NI-VISA 3.5.
But now I want to get my Class RAW USB device connected to Windows 7 64-Bit
Version. I've created a new INF File with the NI Driver Wizard (NI-VISA 5.3), which
is fitting to Windows 7 64-Bit Version. And I've installed it according to the
instructions of the NI Driver Wizard.
My Class RAW USB device is listed on the Windows Device Manager. But it
is marked with an yellow exclamation mark. And when I looking for details the error
message "Device cannot start. Code (10)" appears. And my USB device does
not appear in NI MAX or VISA Interactive Control.
According to the new INF File, on Windows 7 the NIVIUSBK.sys Driver have been
replaced by the WINUSB.sys Driver. Could this have caused the Problem? And is
there anything else to do, to connect a customized Class RAW USB Device with
Windows 7 64-Bit Version, by using NI-VISA 5.3?
For the Class RAW USB-Interface I used the Atmel AT91SAM7X128 Chip.
03-07-2013 04:43 AM
in contrast to WinXP using NIVIUSBK.sys, Win Vista and Win7 use WINUSB.sys. So the entry in the inf file is correct.
Generally the created driver should work. Did you try reinstalling the driver and stuff like that?
See the following link for some troubleshooting steps:
http://pcsupport.about.com/od/findbyerrormessage/a/code-10-error.htm
USB Instrument Control Tutorial
http://sine.ni.com/np/app/main/p/ap/ictrl/lang/en/pg/1/sn/n17:ictrl,n21:25/fmid/6000/
It seems the correct order of steps to create the driver is important, too. Did you connect the device while you ran the wizard and did you disconnect the device while installing the driver?
I also found the following threads.
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/This-device-cannot-start-Code-10/td-p/738038
If this doesn't help just let me know!
03-08-2013 03:58 AM
Thanks for your reply.
Yes, according to the installation instruction, I've ensured the right order of these
steps to install the driver on Windows 7.
I also checked the troubleshooting steps, but it's still the same situation:
I've catched the WINUSB.sys debug trace log, while I've connected my USB device to Windows 7 PC.
[2]0004.0030::03/08/2013-10:11:45.514 - Preparing hardware
[2]0004.0030::03/08/2013-10:11:45.516 - Unable to select the default configuration, failing Start
[2]0004.0030::03/08/2013-10:11:45.516 - Enter: WinUSB_ReleaseHardware
[2]0004.0030::03/08/2013-10:11:45.516 - Exit: WinUSB_ReleaseHardware (STATUS_SUCCESS)
[3]0004.002C::03/08/2013-10:11:45.522 - Handling Device Cleanup
[0]0004.0020::03/08/2013-10:11:45.542 - Enter: WinUSB_D0Entry
[0]0004.0020::03/08/2013-10:11:45.542 - Starting Read Io Target
[0]0004.0020::03/08/2013-10:11:45.542 - Exit: WinUSB_D0Entry (STATUS_SUCCESS)
[0]0000.0000::03/08/2013-10:11:45.549 - PIPE129: (0000002d) Transfer was terminated by a short packet
[0]0000.0000::03/08/2013-10:11:45.549 - PIPE129: (0000002d) Read request for 10 bytes has completed with 2 bytes
[0]1798.133C::03/08/2013-10:11:45.549 - IOCTL_WINUSB_GET_POWER_POLICY
[0]1798.133C::03/08/2013-10:11:45.549 - IOCTL_WINUSB_SET_POWER_POLICY
[0]1798.133C::03/08/2013-10:11:45.549 - IOCTL_WINUSB_READ_PIPE
[0]1798.133C::03/08/2013-10:11:45.549 - PIPE129: (00000030) The read has been added to the read queue
[0]1798.133C::03/08/2013-10:11:45.549 - PIPE129: (00000030) The read for 10 bytes is being handled
[0]1798.133C::03/08/2013-10:11:45.550 - PIPE129: (00000030) Reading 8 bytes from the device
[0]0004.003C::03/08/2013-10:11:50.582 - Enter: WinUSB_D0Exit
[0]0004.003C::03/08/2013-10:11:50.582 - Stopping Read Io Target to cancel pending IO
[0]0000.0000::03/08/2013-10:11:50.602 - PIPE129: (00000030) Resending read for 8 more bytes
[2]0004.003C::03/08/2013-10:11:50.602 - Stopping Read Io Target to cancel pending IO
[2]0004.003C::03/08/2013-10:11:50.602 - Exit: WinUSB_D0Exit (STATUS_SUCCESS)
But unfortunatly I'm not an expert in WINUSB.sys Driver.
Maybe this could lead to the right direction, to fix the problem.
03-11-2013 08:50 AM
could you give me the two inf files you created? Maybe I can find some wrong configurations or settings in there.
Raphael
03-11-2013 09:48 AM
Yes, sure.
prefix_XP is the old INF File, which I use to install the driver on Windows XP PC. This one works well in order to connect a Class RAW USB Device to a PC.
And prefix_Win7 is the new INF File, which I've created by using the NI Driver Wizard Version 5.3. I using this one to install the Driver for connect my Class RAW USB device to the Windows 7 64-Bit version.
Thanks for your efforts so far.
