01-18-2018 04:15 AM
Hi, I'm using NI USB 6353 and want to control it remotely by connecting it over ethernet.. Al my other devices are connected using TP-LINK TL-PS310U. I'm able to connect DAQ over this server like on photo bellow, but I can't see it in NI MAX under devices, and can't find it when I try adding new network device.
Thank you for your time.
01-19-2018 07:28 AM
I believe the issue that you are having will stem from the way in which the virtual COM is being setup. It not something that is supported as a methodology, hence the introduction of our Ethernet DAQ.
- Is this something that you have setup before and got working or something you are trying out?
- You reference DAQ devices through the COM ports, have you tried creating a Virtual COM port from the connection?
Kind Regards,
Matt
AE UK
