Connecting NI USB 6353 to ethernet
Hi, I'm using NI USB 6353 and want to control it remotely by connecting it over ethernet.. Al my other devices are connected using TP-LINK TL-PS310U. I'm able to connect DAQ over this server like on photo bellow, but I can't see it in NI MAX under devices, and can't find it when I try adding new network device.
Thank you for your time.
(2,364 Views)
I believe the issue that you are having will stem from the way in which the virtual COM is being setup. It not something that is supported as a methodology, hence the introduction of our Ethernet DAQ.
- Is this something that you have setup before and got working or something you are trying out?
- You reference DAQ devices through the COM ports, have you tried creating a Virtual COM port from the connection?
Kind Regards,
Matt
AE UK
(2,331 Views)
