Connecting Keithley Sourcemeter 2400 with computer to measure Resistance
Hi guys, I have a keithley sourcemeter 2400. I want to connect it to my computer to measure resistance for each 5 min interval. I want the output of it to be saved in either .txt format or any other readable format. Can anyone tell me in detailed regarding how to do it? P.S. I am new to sourcemeter and labview. Therefore, I don't have any knowledge regarding the both. Thanks in advance.
Message 1 of 10
(12,482 Views)
What driver did you download, which hardware bus are you using?
You can read Voltage and Current when measuring.
Did you use 4 wires to connect?
What did you try yourself?
greetings from the Netherlands
Message 2 of 10
(12,473 Views)
I haven't downloaded anything yet. Planning to use Labview and RS232 port. I have no knowledge regarding the connection.
Message 3 of 10
(12,466 Views)
make sure you use a straight cable (not a null modem cable)
A usb- to serial from ftdichip is also OK
download the labview driver from instrument drivers.net
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/nl/pg/1/sn/ssnav:idr/
an test an example
Message 4 of 10
(12,464 Views)
Can you help me? I have almost the same problem. My teacher told me to work with 2400 SourceMeter and with 2182A Nanovoltmeter, and I never worked with anything like these. I googled everything that I found necessary. I installed LabView 17, NI Max, NI Visa, NI488.2 3.1.2, in my windows 7. Conecting 2400 SourceMeter and 2182A Nanovoltmeter with RS232-USB in my computer installed the drive automatically. After all these, when I open NI Max, it still not recognizing 2400 SourceMeter and 2182A Nanovoltmeter and I don't know what can I do.
Message 5 of 10
(11,065 Views)
Check your RS232 cables, make sure its a straight cable.  Try another model of RS232-USB.  One of those should solve your problem.  You should see virtual com ports that you can use to communicate with the instruments.
Message 6 of 10
(11,042 Views)
If the instruments are connected to an RS232 port they won't show up in NI-MAX. If you were using GPIB, USB or Ethernet the instrument would show up in Max.
It doesn't mean it's not working. Try opening up a visa session with the com port that the 2400 is connected to and send it a few commands and try to read back some data
Curt
Message 7 of 10
(11,040 Views)
Also,
If the instruments are newer models they might have a USB interface. You'll see a connector on the back that will accept a USB printer cable. If it does the device will show up in max looking something like this
"USB0::0x05E6::0x2400::4018686::INSTR"
Curt
Message 8 of 10
(11,038 Views)
I am also having same problem .
I have SMU 2400 series and I want to connect it via GPIB-USB-HS.
I have labview 2014.
How can I communicate them?
Message 9 of 10
(8,978 Views)
Does it have a gpib connector?
Can you send a picture of the back of the 2400, or the interfaces you see there?
Which year and software version is your machine?
Message 10 of 10
(8,962 Views)
