06-24-2019 02:04 AM
currently we have an SCXI1000 connected to a PC with a PCI 6024E-card by means of a multifunctional cable (SH68F-68F-EPM). The PC must be replaced and I fear the PCI 6024E will no longer fit in.
How can I connect the DAQ to the PC? Is there for instance a USB-version, or a USB-"SH68Fcable" converter?
Thanks for any support,
Hans
06-24-2019 04:45 AM
I don't think that the PCI slot will be your problem. There are still motherboards with PCI slots on market (even for current intel 1151V2 socket) . So you should be able to build a custom PC around such a motherboard. However these motherboards require Windows 10 as OS . Are there windows 10 drivers for your PCI6024E ? The USB-1359 Adapter , we are using for our SCXI-1000 chassis has only limited support for Windows 7 ( only 32 bit ). And there will be no updated drivers, because SCXI is considered to be obsolete by NI since September 28th, 2018 ( http://www.ni.com/product-documentation/53722/en/ )
