03-19-2015 11:49 AM
Hey Guys,
I am working on one of the project where I need to access the PORT advanced setting programatically in LabVIEW.
But the serial APIs (VISA) in LabVIEW is application layer APIs.
Please help me with this.
03-20-2015 12:27 PM
Use a property node Class= Serial:Instr To read or write to the advanced properties of the I/O session.
That looks like any and all of the properties you can access on your Jing
03-20-2015 12:52 PM
Jeff,
I am aware of all these properties.(BTW i dont see the buffer properties in the list)
My question was related to accessing the Low-high,receive transmit buffer given in windows property.
In labview class we can change these properties on application level but not on the physical port level.True?
Let me elaborate:
If I change (Jing) "Use FIFO buffer" in LabVIEW it will remain checked even if I change it in LabVIEW.
Please help me to find these properties directly instead of showing me an access to property of the port. 🙂
03-20-2015 01:20 PM - edited 03-20-2015 01:22 PM
Nothing easier Mask selects recieve transmit or both
And yes. you would need to use the Windows Registry functions to change the Windows settings from LabVIEW
