05-18-2022 04:15 AM
I have the hardware (oscilloscope: Hanmatek DOS1102) and did not found any driver for this. So i tried to implement a VISA communication and SCPI commands.
Without success. Is there anyone who has the same problem and has established communication with this oscilloscope or found a driver? I am a LabViEW beginner and am grateful for any tip or VI.
Thank you very much.
05-18-2022 08:19 AM
Please post what you attempted and your observations along with the programmer's manual.
Note: please attach VIs in LV2016 version to cover a wider audience (File > Save for previous)
Since you're a beginner, this video will be a good tutorial for serial communications.
https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
05-19-2022 06:36 AM
Enclose i have added the VIs.
Thanks for the response and the Video.
I hope there is a simpler solution for my problem 🙂
05-19-2022 09:17 AM - edited 05-19-2022 09:19 AM
So what is the problem?
There isn't a "simpler" solution. If there isn't a pre-made driver, you have to write it yourself. This is what happens when you buy a hobbyist scope.
05-19-2022 09:21 AM
Sorry, I know there is no easier solution.
It was related to the video. That was a little too high for my level.
The problem is that I can't get any values out. I don't know how to display the graph from the oscilloscope and read values like max or peak to peak.
It is not showing me anything.
05-19-2022 10:34 AM - edited 05-19-2022 10:41 AM
Getting the graph from the scope is not a trivial task.
Ask your boss to send you for some training.
I can't even find a manual for it. LOL.
Good luck.
03-02-2024 02:53 PM
Here is the manual for the Hanmatek DOS 1104. Read page 16 and. see if you can get a hold of the software. I suspect the driver will work with 1102.
