08-23-2006 11:08 AM
Hello
I'm trying to write Matlab code to measure s-parameters at certain bias points.
The code for the vna is completely finished and I can read all the data I need
to. Now I also wanted to controll the HP4142B (a parameter analyzer) with
Matlab to be able to set different bias points for the s-parameter sweeps.
It turns out, that I'm not able to communicate with the HP4142B, no mater what
I try. I have the command reference book from the HP4142, but can't get the
HP4142B to work. To eliminate the possibility that it doesn't work I attached
it to an old 486 machine with NPTS (an old measurement and controll software)
and set the new Pc with the NI PCI-GPIB+ card up as an analyzer. It appears
that the old dos program can measure and read perfectly from the HP4142B.
When I try using the same commands as NPTS uses - nothing happens. I noticed,
that the control sequences are slitely different, but can't change them to be
the same as from the old NPTS machine.
What am I doing wrong? Why isn't the HP4142B responding? Is there a possibility
to controll the HP4142B from Matlab?
Comamnds used below:
CN6 - enables module 6 in the HP4142B
DI6 - forces output current from module 6
with the output range set to AUTO and the current set tp 10mA. The compliance
Voltage is set to 777mV
TV6 - trigger command for high speed spot voltage
measurement on channel 6 with the measurement range set to AUTO
All the commands can be found:
http://www.home.agilent.com/upload/cmc_upload/All/42B90110.pdf
Here's the analyzer data:
Working
data from the HP4142 controlled with NPTS on a 486
M
Timestamp Data
mi s ms us ns
0 0 0
0 50 UNL ATN^ REN^ TA0 LA25
0 0 0 127 850 ATNv
0 0 0 18 700
C N 6 . . END EOI^
0 0 0 581 350
EOIv ATN^
0 0 0 41 400
UNT UNL UNT UNL SPE TA25 LA0
0 0 57 561 200 ATNv
0 0 0 15 100
0 0 0 106 350 ATN^
0 0 0 61 200
SPD UNT UNL UNL TA0 LA25
0 0 1 345 650 ATNv
0 0 0 75 800
D I 6 , 0 , 2 . 0 0 0 0 0 0 0 9 4 9 9 4 9 0 E - 0 0
0 0 0 913 250 0 3
, 7 . 7 7 0 0 0 0 1 0 0 1 3 5 8 0 E - 0 0 0 1 .
0 0 0 760 350 .
END EOI^
0 0 0 197 500
EOIv ATN^
0 0 0 45 600
0 0 57 658 650 ATNv
0 0 0 15 600
0 0 0 107 550 ATN^
0 0 0 59 500
SPD UNT UNL UNL LA25 TA0 GTL
UNT UNL UNL
0 0 2 558 650
TA0 LA25
0 0 0 126 250 ATNv
0 0 0 21 850
T V 6 , 0 . . END EOI^
0 0 0 632 550
EOIv ATN^
0 0 0 41 250
0 0 57 565 200 ATNv
0 0 0 15 100
0
0 0 108 100 ATN^
0 0 0
61 0 SPD UNT UNL UNL TA25 LA0
0 0 0 496 500 ATNv
0 0 0 159
0 N F V + 0 . 0 2 0 6 0 E + 0 0 . . END EOI^
0 0 1 90 100
EOIv ATN^
0 0 0 64 800
UNT UNL UNL LA25 TA0 GTL UNT UNL
Data
entered with NI-488.2 Communicator from the new Pc with the NI PCI-GPIB+ card
without getting any response from the HP4142B
M
Timestamp Data
mi s ms us ns
0 0 0
0 50 ATN^ REN^
0 0 0 11 400
TA3 UNL LA25
0 0 0 52 750
ATNv
0 0 0 7
600 C N 6 END EOI^
0 0 993 337 650
EOIv ATN^
0 0 0 10 750
UNL LA3 TA25
0 0 0 53 400
ATNv
0 19 318 787 700 ATN^
0 0 0 10 800
TA3 UNL LA25
0 0 0 53 250
ATNv
0 0 0
42 0 D I 6 , 0 , 9 . 9 9 9 9 9 9 7 7 6 4 8 2 5 8
E - 0 0
0 0 1 10 400
0 3 , 5 . 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E - 0 0 0
0 0 0 703 750 1
END EOI^
0 1 297 442 250
EOIv ATN^
0 0 0 11 550
UNL LA3 TA25
0 0 0 54 150
ATNv
0 21 648 452 700 ATN^
0 0 0 11 950
TA3 UNL LA25
0 0 0 53 900
ATNv
0 0 0 7
600 T V 6 , 0 END EOI^
0 0 812 566 300
EOIv ATN^
0 0 0 11 550
UNL LA3 TA25
0 0 0 49 750
ATNv
08-24-2006 08:53 AM
08-31-2006 10:31 PM
09-01-2006 01:52 AM
06-30-2010 08:26 PM
Hello Tube,
I am trying to write labview program for hp4142b and I wish if you could help me to get the drivers for that.
Thank you,
Pratik
07-01-2010 10:05 AM - edited 07-01-2010 10:06 AM
Old thread and as you learned in the other thread you posted to, there are no drivers available for the 4142. You will just have to write your own or modify the 4155 driver as mentioned above.
07-01-2010 12:27 PM
Thanks.
Wish me luck.
07-01-2010 12:30 PM
Oh I forgot to ask one thing.
Which is the best to start with, if I am modifying the code: HP 4145b, HP 4156b, or HP 4155?
Thanks.
07-01-2010 01:28 PM
Personally, I have no idea. You might want to review the programming manuals for all of them. Agilent tech support may be able to help but as the 4142 is obsolete (and perhaps some of the others), there help may be limited. Reviewing the driver code would also be a good idea.
