From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Communication to Vötsch oven
Hello, how to communicate to a Vötsch oven?
(in the past the name of the company was: "Haraeus Vötsch"     now: www.weiss-technik.com)
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 1 of 25
(10,007 Views)
In this attached document there are two communication protocols described: ASCII-1 or ASCII-2.
Most ovens, as I have seen, communicate over ASCII-2 (e.g. $00I<CR>)
Eugen Wiebe
Bernstein AG
Message 2 of 25
(10,005 Views)
This link can also be helpful:
http://www.basytec.de/applications/climate.pdf
Eugen Wiebe
Bernstein AG
Message 3 of 25
(10,003 Views)
If the oven has a RS232 (25pin) connector (like the VT4010 / VT4020) this is the pinout:vötsch 25pin pinout.jpg
Eugen Wiebe
Bernstein AG
Message 4 of 25
(10,000 Views)
In this operating manual also the communication method is described:
http://doc.es.aau.dk/fileadmin/doc.kom.aau.dk/labs_facillities/control/manuals/VT4002_climate_chambe...
It is equal for many Vötsch (Votsch) ovens.
similar:
Communication protocol of VC7xxx
Eugen Wiebe
Bernstein AG
Message 5 of 25
(9,994 Views)
Hello EWiebe,
thanks for sharing the informations. Do you had some additional questions?
best regards
Alexander
Message 6 of 25
(9,947 Views)
Hello! With the info in this thread and some other posts on this forum I have successfully set up communication with a Vötsch Heraeus HC 4120 using RS-232 and the ASCII-2 protocol.
I can set and read the values in the $00I and $00E-commands but I cant find a way to actually turn the chamber on.
Do you have any information regarding how to turn the chamber on via RS-232?
Thank you for the help.
Message 7 of 25
(9,102 Views)
Perhaps this will help...
Eugen Wiebe
Bernstein AG
Message 8 of 25
(9,095 Views)
Thank you for the prompt answer!
The format in the document you sent is different from the one i tried before. I tried sending "$00E050.0 000.0 000011001 00 100 2 0 <CR> according to the document you sent and the chamber answered "0<LF>50.<CR>. It still didn't start.
And when sending "$00I<CR>" The chamber answers "0030.0 0022.5 0000.0 0037.7 0020.0 0167.7 0020.0 0167.7 0020.0 0167.7 0020.0 0167.7 0100.0 0000.0 000010000000000000000000000".
I have followed a printed operation manual I have here and I have scanned the protocol pages from it and attached to this post.
When I use the protocol found there, the chamber seems to work well and the messages fit the format. But I still cant find a way to actually activate the chamber.
The only options I seem to have is to send the E or the I-command, there is no command to start the chamber.
I have also tried sending the "Start program" command "$xxPyyyy<CR>" which I found somewhere on this forum.
The chamber actually starts on that command but it runs some pre-defined program and ignores the value I sent using the E-command.
The chamber also does not answer to the "$00?<CR>" status message that I found some has been helped by.
I think it's strange that the starting of the chamber would be so hard when the settings work so well.
Is there a limitation in the protocol or something which inhibits starting of the chamber, or have I just missed the correct command?
Message 9 of 25
(9,090 Views)
$xxPyyyy<CR>
With the ASCII-2 protocol, this is indeed the command to start an existing program of the chamber.
  • xx : adress of the chamber
  • yyyy : number of the program (0 = stop). Obviously this program must exist in the memory of the chamber.
The chamber answers with 0<SPACE><CR> if the command was accepted.
  • 0 --> 0x30
  • <SPACE> --> 0x20 (\s)
  • <CR> --> 0xD (\r)
Do you only want to start the chamber without running a predefined profile ?
Message 10 of 25
(9,080 Views)
