Communication problems with the Philips PM2525 multimeter
I have a problem to communicate with the Philips PM2525 multimeter. I'm rewriting a program that communicates with 4 instruments. In the old version, which was written in DOS, everything works, but under windows the philips multimeter is not being recognized.
My GPIB-PCII/PCIIA board is installed in the PCII mode, IRQ=7 ,and the DMA channel=none. First of all I have upgraded my driver. The ni 488216 was installed. I installed the driver correctly so I went further initialising my GPIB0 card with the following settings :
Primary GPIB adress = 0
Secondary GPIB adress = NONE
Timeout setting = 10s
Terminate read on EOS = NO
Set EOI with EOS on writes = NO
Type of compare on EOS
= 7bit
EOS Byte = 00H
System controller = YES
Assert REN when SC = NO
Enable auto serial polling = YES
Enable CIC protocol = NO
Bus timing = 500ns
Parallel poll duration = DEFAULT
Then I scanned for instruments. First I checked instrument by instrument. Only the multimeter was not recognized. Then I've connected the 3 working instruments after each other and they where all detected. When I connect the multimeter the scan procedure can't find any instruments. If I run the DOS program the multimeter works and communicates correctly.
Can anybody help me with this question.
Jörgen.
(3,984 Views)
The first thing you look at is the following knowledge base found on our website:
www.ni.com>>technical support>>(Option 3)advanced search>>(type in something like "+find +instrument +gpib" )You should see the following knowledge base:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/72fad7156202ddf9862568900048f006?OpenDocument
Buddy Curtis
Joji
(3,984 Views)
